How to use pinboard
I’m confused.
I’m trying to set up a way to easily add to pinboard things from newsblur.
I tried enabling it under Sharing Services. It took me a while to realize it is not added to “Share” but to an option only found by right-clicking the title of a story. That creates a popup to add the story to pinboard.
This works but seems quite sub-par. The main problem is there’s no keyboard shortcut for it (or IS there?) and it’s a slow process of adding (it’d be nice if I could configure it to add it automatically w/o user interaction.)
Is there deeper integration with newsblur that I’m just missing?
You’re absolutely right. I’ve been wanting to create an OAuth flow with keyboard shortcuts for sharing services for a while. It’s near the top of my to do list.
OK, thanks for the reply. For now I’ll just open -> save.
BTW, I’d recommend renaming the title for “Sharing services” in settings, since they don’t appear under the “Share” button. Maybe name them “Send-to services”? That was very confusing to me until I was about to post here, and it showed the exact same question from someone else :slight_smile:
Thanks for Newsblur!
You make a good point. I’ve long had some confusion about sharing services not showing up under the Share button’s services (twitter/facebook).
