Sa_Li
July 1, 2013, 4:36am
#1
I have about 5/6,000 subscriptions, a lot of them are not updated any more:)
I don’t know if your service can handle that many?
Btw, recently I tried Feedly, found some incorrect updates:(
either missing the unread ones, or shows me some old updates:(
Hope to see promising results from your service:)
The most I’ve ever seen is 3k subscription, but the front-end slows down quite a bit at that load. I have a feeling any higher than that and you’ll be out of luck. Your best bet is to host locally.
Sa_Li
July 1, 2013, 4:50am
#3
Thanks for your updates, and I will try it for some days, to see if any better experiences:)
Sa_Li
August 15, 2013, 4:39pm
#4
Hi, Samuel,
It seems that the support for my subscriptions is still a problem, and I have to give it up:(
Can I get refund for my account?
Thanks a lot!
Best Regards,
Sa Li
my email: sali98@gmail.com
