Gawker sites (like io9, Kotaku) currently bubble up their “top” tag on an article into the post title in [square brackets]. I realize this may be special hard code for only a single network of sites and I’m not sure if there is a more general solution, but would it be possible to pull out these bracket tags so that they too can be filtered like other tags?
You can use post titles (or parts of post titles) in the trainer. Just highlight the bit in brackets and you’ll be good to go!
Thanks, that was what I was looking for. I hadn’t realized how context sensitive the Intelligence Trainer was and apparently had not tried it from a single post. It also turned out that those did show up as tags, too, just apparently not big enough ones to be on the Feed’s Trainer.
This should become more obvious in the social branch, where “Train this story” is much more prominent.
