Feed won't add to Newsblur
I have one feed that will not add to Newsblur no matter what url I use, it works fine with Google Reader. http://metaphysicalarticles.blogspot… or http://metaphysicalarticles.blogspot…
Otherwise, I’m up and running fine, thanks :slight_smile:
I hate to complain but while I can’t add important feeds I’m having to double check all the time with Google Reader. I know I’m not the only one with this problem and it is a little thing but I do think speed and being able to add feeds is of paramount importance in any reader. You’ve done a great job so far but this is a basic need that needs to be addressed. Thanks
