I know there is an option to select the oldest unread item first when reading, but I’d really like to see this as a per-feed setting. Most of my feeds are fine reading top to bottom, but a handful (Forums, sequential literature) are best suited for forward chronological reading.
How would you set it? The same preference from Manage > Preferences in the Site Settings option? I think that may be over-doing it. The reason it’s a global preference is that the ideal setting, show stories sorted by date, will be a global as well. If enough people want me to allow you to split it per-feed, I’d consider it, but it’s not quite like the Feed/Story view to warrant every feed being overridable.
Yes, I envisioned it as another option in the manage > preferences > Site Settings.
On the contrary! I’ve used that override… maybe on one site? Maybe none at all. Meanwhile, I’d override sort order on at least a dozen (roughly 10%) of my feeds. At the end of the day, I don’t read every feed in the same order. Some should (or should I say must) be read sequentially. To me, it just seems obvious that this (and the sort option you mentioned) should be manageable on a per site level. The idea that hundreds of feeds should all be read and sorted in the same order seems really preposterous to me.
This is by no means a deal breaker for me, but sits very [very very] high on my “nice to have” list.
That’s pretty convincing. OK, when I finally build the actual read oldest-to-newest feature, this will be part of it. Unfortunately, got to launch social and the backbone-rewrite first. 2 months? Oldest-to-newest is high on my list.
By the way, this also means I’m going to be adding a button somewhere in the story titles pane so you can switch between the two (oldest/newest first).
Awesome Samuel! Gives me something to look forward to after the newness of the social features wears off
