feeds.feedburner.com/BringaTrailer looks OK in other viewers, but NewsBlur (.com and iOS) has been filtering out most entries for the past week or two
You likely have inadvertently trained stories on this feed. Try right click or opening the menu for the feed and going to the intelligence trainer. That will show you some word or author in red.
That’s what I assumed as well, but nothing was highlighted either way in the intelligence trainer. I even deleted the feed and added their alternate (https://bringatrailer.com/feed/ - maybe just an alias for the other). Same filtered entries. Is there some other filter cache I can try clearing? Upon closer inspection it looks like every entry with a title prefixed with "BaT Auction: " is filtered out.
I have the same issue. I don’t use the intelligence trainer and checked it to make sure. None of the tags are highlighted.
