Newsblur doesn’t seem to be able to load this feed: http://www.rifters.com/crawl/?feed=atom (this feed works in Google Reader) - is it a problem Newsblur can fix? Or should I report an issue to the feed author?
Same problem here. It’s the only one of my feeds that won’t load. And it loads in other readers…
It’s sort-of a problem with the feed. One of the posts has some URL-encoded images embedded in the story text, making the feed very large (something like 2-3 MB, IIRC). This is over whatever size limit NB has on feed XML, so it fails to load.
Fix would be to either:
- bump up the size NB can allocate to reading a feed; could potentially impact performance if malicious user(s) decide to point NB at multiple large feeds
- get Peter to change those images into normal linked images, instead of embedding all of the data in the feed
Temporary fix: use a feed URL that excludes categories of the offending posts (used “writing news” tag for post “Slepogled” and “deep sea” for “Did I call it? Did I call it?”)
Use http://www.rifters.com/crawl/?feed=at…
Eventually the offending posts will age out of the feed and the tag restrictions can be removed from the feed URL. I added the modified feed URL and NB now loads again.
