Hi! I have rss feed http://acomics.ru/-malef/rss
There is last item from this feed on newsblur site dating february 15, 4:19 pm. But if I open this feed directly in browser then i see that its ok and there are new items after 15 february. At the same time other feeds work normal on newsblur. help me please to fix this feed.
The GUID, is not a Globally Unique Identifier, as they’re all the same.
what? i didn’t get how does it refer to my problem?
There is a GUID field in the RSS.
This stands for Globally Unique Identifier.
This refers to the unique “post” that has been updated. So if there is a new “post” on the site, it should have a new GUID in the RSS. If an existing “post” is updated, the coressponding RSS entry, should use the old GUID, with a new timestamp.
All the GUID fields are the same: http://acomics.ru/~my-zombie-days#
thank you! i’ll try to get help from tech support of this site then.
