Everything older than a month marked as read?
How do I disable this?
You don’t. There is no setting for it. It’s just the way Newsblur works. It used to be just two weeks.
Give it a bit of time and you’ll get used to actually reading stuff or marking it as read yourself long before it becomes a month old, I did.
But FYI, if it’s something that you need to keep, you can save it, and it will be in your Saved Stories indefinitely.
