When I attempt to read ESPN articles, they freeze up and then I get sent to ESPN’s site (and out of Newsblur’s site). Are other folks having this problem as well?
Try using the Feed view instead of Story or Original view. Does that help?
Yes it does, but I’m absolutely hooked on the “story” default setting. I could also live with the “text” default setting (if there was one). Is there any chance you’ll add that bit of functionality to your software package? Aside from my very minor quibbles, you’ve built an outstanding product. Keep up the good work!
Sorry, ESPN has actively disabled the Story view. Not much I can do, unfortunately.
