Is there a way to turn off the next article preview pane on the screen? I know about the buttons in the upper right hand corner, but that seems to give me the feeds in list view only and removes the option of Original or Story view mode.
Hit shift+t.
Awesome…thanks a lot man for answering these questions. We all know how busy you are making Newsblur amazing and wanted to let you know that we all appreciate your hard work.
In regards to this question…might be good to have the option to turn it off available under preferences where you can position it to the bottom, left, and top (side question…why no option for right? Im on a 1080p monitor and always have a ton of white space available to the right).
Anyways thanks again!
