Steps:
- Select a feed in the feeds list
- While the feed is still selected, right click on the feed and select a menu item (I used Mark As Read)
Result: The context menu remains visible
Sometimes this happens if you perform the same steps on a feed other than the one currently selected. When that happens, the feed disappears from the list (I have it filtered by Unread), but the context menu remains visible, attached to nothing.
In either case, I would expect that the context menu would disappear after selecting a menu item.
