Constant timeouts on specific feed
The following feed is broken most of the time:
http://spielverlagerung.de/feed/
Newsblur shows a 505 Timeout. “Fixing” the site seems to work, but a few hours later the feed is broken again.
The problem is still there, there are only a few followers of this feed but I hope it can be fixed.
Yeah, some sites don’t do well under NewsBlur’s 20 second timeout. Not much I can do, since if a site isn’t performant enough in 20 seconds (most sites are less than half a second), then it just won’t work on NewsBlur.
Insta-fetching forces a cache buster, by the way. But normal fetching uses whatever caching the site has.
Ok, at least I know it’s a problem on their side.
I also have the same problem with https://www.privacyinternational.org/…
(https://www.newsblur.com/site/1071643…)
Clicking the button to parse this RSS/XML feed eventually returns ‘There was a problem fetching the feed from this URL’
It is listed as having 15 subscribers.
(Loading this feed directly in Safari is fast.)
