This behaviour only occurs when I am logged in. If I follow the reproduction steps after logging out, the sample feeds etc all behave properly.
I am reasonably confident that this behaviour did not occur yesterday as late as 5pm Eastern.
I am running OS X Snow Leopard, with all updates applied. I can reproduce this behaviour in Safari Version 5.1.1 (6534.51.22), Chrome 15.0.874.120 and FireFox 5.0.1.
Steps:
I log in.
I click “Everything” in the left-hand frame.
The bottom frame opens, and the “Fetching Stories” and “Counting is Difficult” progress bars start filling. After perhaps a second, the entire screen goes blank.
So far I have been able to read my feeds individually so I can work around the problem.
I ran into this with Firefox 7.0.1. I went through my feeds in the folder that was causing the problem one at a time and found that it was the feed from Saturday Morning Breakfast Cereal that was jamming it up. Once I marked it as read, everything worked again.
Same here. I was about to file a report myself, but then thought it might be something about my workplace firewall and decided to hold off til I could test at home.
It’s definitely caused by SMBC. That feed contains Javascript in the feed itself, which makes me suspicious of it… I don’t know if it had Javascript before today or not.
Yup, this is a direct result of allowing Flash movies in the Feed. Now JS is being executed. What I need to do is strip all script tags, hoping that the sites are using object and video tags. I’ll get to this promptly tonight.
I don’t subscribe to SMBC, but what happens is after a while my feeds don’t load at all. I’ve found a workaround that sometimes works (click on the top level folder) to view all unread in that folder, and then click on the feed, and it sometimes loads. But the only thing that gets the feeds to load for good is to log out and log back in. And then, at some point later on, the feed won’t load. Maybe a different issue…?
I am having the same issue where I click on a feed and it will load but then the whole screen will go blank. I am pretty sure this is related to the javascript in the feeds now. By the way, I love having the feature and it improved my feeds since the audio/video is now embedded. There have been more issues since then though.
The feed I am having trouble with is one of my Huffington Post feeds. I am not sure what the actual link is though.
OK, I just pushed out a fix for this. I’m not sure if this will correct old stories, but new stories should no longer have this issue.
The fix was to start sanitizing HTML again, but preserving object, embed, and params, which are necessary for Flash videos. Please, please, please let me know if you still have any issues. Note that this will take an hour or two to work through all of your feeds, and then it may or may not fix feeds to correctly display content again. Based on what should be happening, the blank screening should no longer happen, but videos may no longer appear if they are from the past day or two. New videos will work, and no more white screening. Keep me updated with what happens for you.
And if you want to instantly fix a feed, just use Insta-fetch stories.
Getting the same issue today (at least I think so, when I click everything it starts loading the status bar then stops and says “oh no an error occurred”). The screen remains blank and I don’t get to see any feeds.
After going through every one of my feeds one by one I discovered it is http://spacecollective.org/recent and after marking this site as read everything worked again.
Thanks for finding the blog! I’m going to add it to my watch list and see if I can figure out a systematic way of stripping out the bad parts of the feed (which is causing the white-screening).
