Hi.
The android app is not loading data about my feeds. It is showing read feeds as unread, after opening a feed it does not load the articles, it is acting strange…
app version: 4.3.1b1
android version: 5.1.1
device: lge LG-D802 (galbi)
username: LukeBronsky
memory: normal
speed: 0 feeds in conn:0 read:0 parse:0 store:0
premium: unknown
prefetch: no
keepread: no
NewsBlur was in maintenace mode for an hour just now. Shouldn’t happen again.
Android app hasn’t worked for me since yesterday. All it will load is saved items and previous cache…no refresh.
android version:
device: samsung
username:
memory: normal
speed: 285 feeds in conn:572 read:50 parse:109 store:74
premium: yes
prefetch: no
keepread: no
Hi. Unfortunately no, the main page does refresh but when feed is opened nothing happens, no articles loads.
If you are on the feed list and pull to refresh (or select ‘Refresh’ from the menu), what sequence of status messages do you see at the bottom of the screen? Do feed unread counts update, or are those stuck, too?
Maybe this will answer your questions better https://drive.google.com/file/d/0B6l0…
That is extraordinarily helpful. Can you log out and log back in and see if it rights everything?
Great, it seems to be working. Thank you!
